Off-Topic Lincoln LS Traction control
Christoph
Sep 2003
Indiana
345
Sorry for the Off-topic question.
Was driving a 2001 Lincoln LS on the Highway when the traction
control started to apply the brakes slowing me way down. Made it home and let the brakes cool for awhile. Got in and foun that
the brake pedal is very mushy and it has very little brake
action. Any body got a clue on this. how about a location for
the trac/control relay. Also smells like a burnt motor
or solenoid somewhere. Thanks for the help!
PS GO COLTS
Christoph,
The burned motor smell is probably due to overheated brake pads. Some times a forklift driver at work will forget to release the parking brake & the smell is terrible when they drive by my work area. Mushy pedal could have a lot of different causes, water in the brake fliud, air in the brake lines, worn brake pads, bad power brake booster valve, etc....I can't imagine why anyone would connect a traction control device to a vehicles braking system. I have seen stranger things before though. I usually think of a traction control system as one that directs the power from the engine to the different wheels depending on the amount of wheel slippage at the time. Kind of like the full time 4 wheel drive that kicks in only when needed. Sounds to me like you had a disc brake caliper freeze up. When the caliper freezes in the clamped position, the pads won't back away from the rotor when the pedal is released. Your problem could be something entirely different though. With modern anti-skid brakes in use I would take it to a reliable shop for repairs. Indiana winter is hard on the cars parts.
Oh yeah GO Colts
I assume you had 'Traction Control' displayed, and that's how you know it was applying the brakes. One wheel sensor partially failed. If it failed fully, the computer would have detected it. With a partial failure, the computer thought you were in a slide.
The mushy pedal is caused by warped brake pads from overheating. They need to be replaced.
There's also a good chance you also have warped rotors. Overheating rotors will get a hard, smooth surface. If that happened, there's nothing you can do to fix them. That's probably why you have little braking action. Continuing to drive with the brakes applied possibly caused a lot of damage. Towing would have been cheaper.
Disconnecting a wheel sensor should cause a fault and disable the system.
Simple ABS is a good thing. It keeps the wheels from locking up by reducing brake pressure on the offending wheel(s). Traction Control is a different matter. In addition to the standard ABS system, it can also apply the brakes. That's fine, as long as it can tell the difference between loss of traction and a hardware failure.
I'm a GM man, and fully trust the system on my luxury SUV. I don't have anything nice to say about luxury vehicles from Ford.
This is the motor nameplate from one of the powder hoist motors on the USS Texas an older generation battle ship, built in 1911-1914 ish. The...
297
Totally off topic, but strange observation. I purchased a few cisco ethernet switches off of ebay some years ago. They are part of a home lab...
2,090
Good morning, Please excuse me if this is too off topic here, but it is a programmable controller of sort. I have an Omron ES100P temperature...
2,361
Which way is up and what's that strange looking bug? I was trying to login to micro_cr*p team_Shi* and it wouldn't let me because I exhibited...
2,723
Hi folks, I have a hydraulically driven rake in a clarifier that rotates at about .18 rpm. When there is a process upset, the bed of the...
3,747
