OK AD ethernet problems..... and going nuts (REVISED) sorry for the boo-boo
BoxerBrats
Jan 2005
Chico California
187
Ok went out today to load in programs into the plc, touch screen ect... set everything up using a ethernet, used a thernet switch (3 COM) first time to run this, and have problems.....
I set up the ethernet card on the touch screen to Node 3, the 450 PLC ECOM card to node 2, and the 250 ECOM to node 1. When I hook my laptop, to access these it see all 3 nodes, but gives me a protocal error everytime i try to connect to a certain node.
I notice even though when I look at them through NetEdit3 it show all 3, aqnd the appropoiate nodes, but I notice the IP adresses are all the same 250-250-250-250-250
I tried changing them but it goes back to the same IP address.
I will be the first to admit, this is all new to me, I done alot of PLC programming, but first time sitting up a ethernet
if anyone has a clue let me know thanks...
unexpected problem happening when connecting said panel to a CJ2M-CPU35 via Ethernet (was replacement of broken NT21 via NT Link). The machine...
661
Hi, new to the forum, and desperate. I am trying to connect a RedLion G308 via ethernet to a Logix 5562 PLC. I am connected via a switch directly...
1,793
I have a question on an install I did last week one of you guys may be able to help me out with. I don’t have all the model #s of the PLC and HMI...
19
6,075
Hi In the project that is attached to the file. I want to add a new OS. Why is the connection to the Ethernet network interrupted by connecting...
2,029
I have recently added a ControlLogix 1756-L72 5570 to our industrial network and brought a number of tags into our existing ignition project...
1,987
