[:ol Negative number nightmare!
titoyabril
Oct 2007
mount dora
17
I am seeting up a temperature controller using PID. I have a steam valve and a cooling valve.
I set up the PID output to be Bipolar (-4095 to +4095).
The analog cards are both setup for unipolar 0-4095 input.
i would like to control the cooling valve with a 0 to 4095 signal, and the steam valve with a 0 to -4095 signal (of course i can't use the negative number.)
The output of the PID is in binary, and the analog cards take bcd.
How do i invert the negative binary number, to a positive bcd number.
The question i am proposing is as to how i can control the 2 valves with 1 PID Output.
By the way, i am using a DL260 cpu and directsoft 5
I understand that it may sound like a dumb question, because i know that if you multiply a number time -1 it becomes positive. But the software does not seem to allow for that.
Hello, I have a Micrologix 1400 PLC and using RSLogix 500. Using a Multi Ranger Ultra Sonic Level Sensor and the input is moved to N7:11, then...
3,901
Hello, Background with PL7 and just started with SoMacine 4.2 Logicbuilder. I have Modbus Slave reading an analog value into a Word. All works...
1,705
Hello All On the plc (s7-315dp) actuel value db11.dbw30 is -200.But i cant see that value on the wincc flex.(i see like that #####) Also...
4,129
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
62
I am troubleshooting an actuator which is not responding to the plc code. The range in the channel of the Allen Bradley 1756-OF8 Analog card is...
630
