Old machine
josesaucedo
Nov 2005
Van Nuys, CA.
78
Hello Folks,
I've been here in this forum in the past getting some help from people in this forum about PLC. I'm intermidiate student without that much experience as most of the people in this forum.
I have a machine that has been down for a year already. When I was asked to turn it on, I found it without responding, I checked the PLC status light and found the error indicator flashing. PLC is dead or no more program stored.
I would like to try to make it work, but I need to get an Allen Bradley PLC because the one it has is an LG and I dont have software and cable for it.
I do have for AB.
Can I feel free to ask any question to any body if I get stuck with this?
Thanks.
Jose
Of course.
Do you have a copy of the original LG program? That will be a huge help. Also, which LG model?
Thank you Alaric,
I don't know what AB model to get if the micrologix 1200 or the 1500.
I'll let you know.
Jose.
These are the I/O of the PLC.
I/0 (P00) Manual/Automatic switch
I/1 (P01) Foot switch
I/2 (P02) E-Stop
I/3 (P03) Corner Cleaning Select
I/4 (P04) Profile Clamping
I/5 (P05) Heating plate feeding
I/6 (P06) Head feeding
I/7 (P07) Head Horizontal moving
I/8 (P08) Locating Plate Feeding
I/9 (P09) Clean Out Corner
I/10 (P0A) Clean Surface 2
I/11 (P0B) Clean Surface 1
I/12 (P0C) ---------------
I/13 (P0D) Single/Linked Action Select
I/14 (P0E) Heating Timing Start
I/15 (P0F) Welding Timing Start
I/16 (P10) Left Head Melting in Position Check
I/17 (P11) Right Head Melting in Position Check
O/0 (P40) Left Clamping
O/1 (P41) Right Clamping
O/2 (P42) Head Feeding
O/3 (P43) Left Head Horizontal Moving
O/4 (P44) Left/Right Heating Plate Feeding
O/5 (P45) Left/Right Locating Plate Feeding
O/6 (P46) Left/Right Head Clean Out Corner
O/7 (P47) Left/Right Clean Surface 2
O/8 (P48) Heating Time Relay
O/9 (P49) Welding Time Relay/Squezzing Pressure Valve
O/10 (P4A) Left/Right Clean surface 1
Thanks for the information Alaric.
Do you think the KGLWIN programming software supports the LG K7M-DR305?
I see alot of K... series that the KGLWIN supports but I don't see the K7M.
Thanks,
Sincerely, Jose.
Sorry Jose, I'm not an LG expert so I can't answer that question. There are members here and at the MrPlc.com forums who do know LG PLCs, maybe a thread asking that question with LG in the title will get their attention.
I just got a work order to change a rusted out box with a bunch of wires going through it. The box has conduits coming from it that goes in 5...
3,497
we will modifie a old bale opener machine and we use S7-300.There is a rail and A and B side of the cotton bales available.If the request came...
2,055
There are the old machines. First- "VOEDING VAN B01-HS7". Snd- "VOEDING VAN B01-HS13, KETTNER VDE 0660-5/0113/IEC439 type KAF 1200". There is...
2,019
I have one old Ansaldo VFD from 37kW and it have only sign OFF on the display after put it on the 3x400VAC. Is there any idea, how to solve this...
88
