Old Square d HMI
jonwayne1951
Jul 2006
SC.
I need to replace a square d hmi with a new and avaible product.
needs to have ethernet and drivers for old 350 and 400 series Square D Processors
I did a job a while ago where we used Citect as the scada, BUT (here's the rub) we used an interface card from a company called Niobrara (I think I spelt it correctly) that mounts in a PLC slot and basically convetrs Square D protocol to Modbus. Then set Citect up to communicate with an IODevice that had been setup as Modbus TCP/IP. It was reasonably staright forward tos et up and worked well. main reason we used Niobrara and not the PC interface card (SA85 i think) was that at that stage anyway there were issues with getting the OS (Windows NT)to recognise the SA85 card
We have that driver on our older HMIs, but don't have it ported over to our G3s yet. If you can't find anything, let me know, and I'll have someone work something out for you.
This is admittedly a pretty obscure problem, but maybe someone else has run into it, or at least something similar. For reasons I won't get into...
134
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
231
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
99
Hey all, I am currently working on a depalletizer for a customer and we are doing a hoist upgrade. This is a SLC500 processor and the drives are...
306
Hi, One of my customers has an old fabric tensile testing machine. The IC # AD7501KN of its controller has malfunctioned. This IC is related to...
86
