Older S7 300 and MC Download
geniusintraining
Jun 2005
SC
8,283
I have a older 314 that I built for a customers as a trainer, all good... programmed and everything works great BUT, the customer wanted a MC, the only MC's I have are used so I am assuming that they have programs loaded on them ?
I have tried everything but cannot figure out how to download the program to the MC
If I power down and install the MC I lose my com's when I power back up the CPU, I have tried RAM to ROM and everything else that I could find, if I leave out the card and run off the battery it runs great, I have also tried a couple different cards and CPU's so I am 1000% positive it is ME and not the hardware
Is there a way to just clear the MC
I am also using Step7
ANY help would be great... I will try it again tomorrow
Thanks!
Unless you have a Siemens memory card reader, the only other way to to clear a memory card (as far as I know) is to browse to the CPU via accessible nodes. Then open the blocks folder, select all and then delete.
We met in Columbia SC
I use a field pg with a built in prommer
If you need assistance let me or Greg F know,
I can help
Thanks!
Git, do a search for "MMC image" on here (Tisher for the posters name I think).
This was an old thread and helped out a lot of people,
Haven't used myself (yet!)
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
481
Hello, I am trying to streamline an AOI that will get module/controller statuses from ethernet IO tree. Everythings fine, however, does anyone...
1,577
Hi, is there any way to export all contents of Block folder (OBs, FBs, DBs, etc) to a text file? I know it is possible to export symbol table, but...
1,246
I was looking at a Studio5000 PLC file as reference, and noticed the "standard" for this job used was using program tags for each program folder...
1,578
I'm looking for someone that may have a download file of TIA Portal V14 and 15. I have a customer that has 2 PLCs on is a 1212C with firmware 4.5...
3,346
