Omega DMD4059 load cell conversion
Dariusincj
Jul 2011
Missouri
43
I'm searching around trying to find an equation i can punch into my AB 1769 processor. I have a 4-20mA input card, that is connected to an Omega DMD4059 signal conditioner that has a 0-10v input on that. Wasn't sure if i should just convert the 0-10v into a 4-20mA and then convert that into my load cell min/max weight allowed? Any thoughts?
Hi, I did a few projects recently with a lot of analog I/O. I didn't think one could mix units--V and mA. I've had a few customers who had V or mA capability on the same analog input card, meaning one could wire to volts or mA. You may have seen those. I know I had voltage inputs on say a valve position, and mA inputs on temp sensors. And on those dual purpose cards I could land both on the same card. You might look into that. Hope this helps.
Hi. I am looking for help. A client of mine has an old Omega PLC (Yellow/orange looking). Either help in sweden, or english/swedish litterature...
3,362
Looking to see if anyone has setup a ControlLogix Via Ethernet to a Omega Temperature controller CNi16D33-EIT-AL. Omega sent me an i-Server users...
972
First hello to all. I have an AB 1768-L43 CPU and would like to read data from an OMEGA/NEWPORT temp controller VIA an Ethernet connection. The...
2,283
Last week I had a Micrologix controller die on me and we lost the program for our overwrapper. Contacted Italian company Impianti Novopac and they...
1,269
What are the differences in the Omega G3 and the regular Red Lion G3? I see the color difference in the faceplate. Are there any firmware/...
14,224
