Omron 3G3MV Inverter - PC Comms
Jan 2007
Sheffield
Hi, I need to pull the settings from an omron 3G3MV inverter using cx drive. I've ordered the relevant cable but does anyone know the pin outs. I need the settings now and the display is shot. Cheers richard
your Inverter 3G3MV... type? I ONLY can read from n1 to n179 from inverter 3G3MV by CX-DRIVE. hope I can help you what you need!!!
BEST REGARD!!!!
MY NAME: BUIPHUQUOI
BEST REGARD!!!!
MY NAME: BUIPHUQUOI
Hello Richard,
According to CX-Drive help...
PC --- Inv
2 ---- 7
3 ---- 6
5 ---- 2
Hope this helps
HI Paulus!!!
Can you help me?! I cant connect PC and Inverter 3G3MV by RS422/RS485?although, I used K3SC-10 (Omron) unit, but I cant do.
Thank you very much!!!
Best Regards! PAULUS!!!
BUIPHUQUOI
Is the drive set up to actually communicate 422/485?
If your display is shot, you should be able to get another one easily enough.
Chapter 7 in the MV user manual deals with communications. If you do not have one, let me know and I can get you a link to one.
HI Leadfoot!!!
Can you help me?! How to set to I can connect PC and Inverter by RS422 or RS485? and CABLE connect beweent PC and Invereter?
Example:n1=?...............n179=?
Best Regards! Leadfoot!!!
BUIPHUQUOI
buiphuquoi said:
HI Leadfoot!!!
BUIPHUQUOI
Hello Buiphuqoi,
You shouldn't need to set any parameters within the inverter to allow connection from CX-Drive. n154 (Baud - 9600) and n155 (Parity - Even) are read-only.
Use the pin-outs as shown previously (note - the inverter connector is a CAT5 type (typically ethernet) - even though the comms are RS422.
Use this cable arrangement, and then use Auto-detect facility in CX-Drive.
Good Luck
HI Paulus!!!
Thank You very much!
I used ok, I can upload n1....n179 from inverter,by use:
PC --- Inv
2 ---- 7
3 ---- 6
5 ---- 2
Please! Can you help me!
But:
I cant Use the pin-outs as shown previously (note - the inverter connector is a CAT5 type (typically ethernet) in my company.
Because:
once at once, I openned panel control inverter 3G3MV.I need no open panel and connect by RS422 or RS485 to PC connect Inverter (R+,R-,S+,S-) by CX-DRIVE to see N1..........N179 in process production.
BUIPHUQUOI
HI All!!!
My Inverter show erro:F00.I pushed any panel's key no working. I cant Reset erro.Can you help me!!!
Thanks!
Best Regards!
BUIPHUQUOI
DO NOT plug a cat 5 cable into the MV and a computer. It will destroy the ethernet port on a computer. There is an adaptor to ethernet for using the serial port on a computer to the MV.
The FOO faults indicate the digital operator is not connected correctly. You can use a Cat 5 cable to extend the operator away from the drive. We door mount the operators all the time with a Cat 5 cable.
I believe you are trying to use the terminal strip points to do your communications.
If you do not have a manual for the drive, go to www.idmcontrols.com click on DOWNLOAD scroll down and on the right you will see links to all of OMRON's drive manuals. They are in pdf format. Chapter 7 is info on communications. I need to look at CX-Drive. You can get drive wizard and information on how to program the drive with the PC. You still need the adaptor. I will try to get you the correct pin out. I have one and need to find it.
EDIT: do you have the CX-DRIVE manual?
HI Leadfoot!!!
Please!Can you help me?! How I looked DRIVE wirard but I cant see how to a CABLE connect beweent PC and Invereter?
Example corporeity:
PC Inverter
pin1?-----pin?
ect...
Can you give me a image connect beweent PC and Inverter by Dive wizard program?
I know English a little. I am sorry!
HI Leadfoot!!!
I have not Cx-Dive manaul. Can you give me a one!?
NOTHING COULD HAVE GIVEN ME GREATER PLEASURE THAN TO GET NEWS FROM YOU!!!
BUIPHUQUOI
HI Leadfoot!!!
Example:
PC Inverter
pin1?-----pin?
ect...
Can you give me a image connect beweent PC and Inverter?
HI Leadfoot!!!
BUIPHUQUOI
Good Call
Hello Leadfoot,
Well pointed out. (y)
I should have stated that the PC end is connected to the Serial Port using a standard 232 D connector, and the CAT5 connector is used at the inverter end (where the programming console is connected).
Sometimes the obvious is not so obvious!
please i need a help,i have an ac motor conveyor replaced,which is controlled by omron 3g3mv inverter.how can i change the frequency of this...
1,677
Hello all Please who can give me the n01 to n179 parameter setting for sysdrive 3G3MV Inverter to run in pulse train control. All contribution...
3,936
currently operating machine that is currently using a CJ1m-CPU22 this sends an analog output to FR-FC inputs on the drive then links the next...
6,450
Good morning everyone I’m currently working on a omron device net and have a nord drive that fell off the network. I have limit knowledge in...
148
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
87
