Omron and Hitech electronics
Estring
Mar 2015
Israel
Hi Experts,
I'm facing with a problem in next configuration system,
SYSMAC OMRON C200H CPU01 PLC with LK201-V1 communication module and Hitech Electronic HMI panel(very old), the problem it's not communicating i cant find out where is the problem either the HMI communication port not working or communication module on PLC.
How could i connect to the PLC and make any diagnostics about the communication, which software should i use for this type of CPU? and which cable? I've never worked worked with OMRON PLC.
Thanks in advace,
Best Regards
Greg Estrin,
http://www.estrin.co.il/#!home/mainPage
2015-03-15 21.23.47.jpg 2015-03-25 20.45.33.jpg 2015-03-25 21.11.27.jpg 2015-03-25 21.31.40.jpg 2015-03-26 12.37.50.jpg
Good morning everyone I’m currently working on a omron device net and have a nord drive that fell off the network. I have limit knowledge in...
112
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
86
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
215
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
87
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
155
