Omron and storing program to EEPROM
koron
Jun 2009
Hluk
Hello all,
we have CX Programmer V 5.0 and PLC CQM1 with CPU21. We can edit program, but when we switch plc off/on, then original program from EEPROM is reloaded. We did not find any possibility, in CX Programmer, how store edited program to EEPROM. My question is: "how can I store it to EEPROM ?"
Thanks in advance
Petr Slovak
I do not have time to look things up now but if you get hold of the manual for the PLC, download from Omron, you can write to the EEPROM by setting DIP switches on the processor - it is a hardware thing not CX-Programmer.
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
157
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
104
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
257
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
140
