Omron C200H upload problem
TEOWK
Oct 2004
Batu Pahat
38
I have a OMRON C200H CPU21 here. I tried to upload the program using CPM1-C1F01 but fail to upload the program. But if I connect to C200HS PLC, the upload process is sucessful.
Please advise how am I able to upload program from C200H.
Do these peripheral port on these model have different protocol?
Thamk you. If there is a Host Link communication card, with model C200H-LK201 attached on the CPU backplane, can I use this communication module to upload the program?
I have tried to use COM2 on my PC, with a a 25 pin to 9 pin on the PC, link 2-2, 3-3, 5-7 to the 25 pin on the PLC, with RTS and CTS short-circuit in PLC side, it seems no respondat all. Why?
On the front of the 201 :-
SW 1/2 = position 0 (node)
SW 3 = 5 (baud rate)
SW 4 = 2 (data)
on the rear of the card 1+2 off , 3+4 on
CTS 0V switch set to 0V
try that and you should be cooking on gas
I have a sysmac omron plc C200H CPU01,only the power led is ON,using CX-ONE programmer software, and connecting to the plc via Host link LK202-V1...
714
In order to upgrade a control unit, we need to backup program of an omron C200H CPU01 with host link LK202-V1 that has RS422 D9 Connector. Please...
629
The logic seemed to convert nicely, and I had to make changes to the addresses for my AD and DA and 32-point input cards. The current problem is...
1,037
I am trying to display some scaled analog input values on a C-more Micro terminal, from an older C200H Omron PLC. The addresses appear to simply...
2,181
I have a customer with the Omron C200H that occasionally will start flashing the alarm light and the machine stops. They say they can power down...
3,053
