Omron C200HE LAN connection
Unfortunately there is not Ethernet option for the C200 range. There is the option of upgrading the Backlane & CPU, and maintaining the existing IO modules. This would then allow for you to add a Ethernet module to the rack.
The other option would be to get a Ethernet serial device server.... all depends on what you are wanting to acheive.
There is a PC Card Module available for the C200HE.
Part Number C200HW-PCU01-EV1. This is a module that uses a PCMCIA card. Technically you could install an Ethernet adapter in this module.
Practically speaking, this probably is not feasible.
I just checked the price and in the US the list price is $3710.37. Serial to Ethernet converter would be much more cost efficient.
Hope this will help.
Hi! I am having a problem with the C200HE. It has a SRM21-V1 communication module with SRT1-ID08 remote input module. I think the protocol used...
1,664
Hello..all i have 1 project to upgrade C200HE to CQM1 omron plc ..need expert suggestion been told to change old model to CQM! model ..which i...
3,763
hello all i would like to seek some advice and also some guide for my problem as below . 1st.. lately i been having problem with 1 plc (cimon)...
1,706
hello all... i would like to ask help or suggestion on problem me facing on omron c200he plc.. i had mounted addtional output unit od215 to...
1,807
hell all... i have a small project going on whereby it was install working for weighing hooper and loaded to truck (tanker) .. problem is the...
2,736
