Omron C200HG
Pricop
Mar 2021
Brasov
I have a problem with a Omron plc,model HG200 CPU 43;I'm trying to connect with it but the error led is blinking.On the male serial port of the CPU I have short circuit pins 4 with 5,on the female serial port of the PC I have short circuit 4 with 6 and 7 with 8.I can't detect it with CX-Programmer (v9.7).The comms for Hostlink, 9600, 7, E, 2,also dip sw5 on.Do I need to turn any other off?I have all of them on beside 6.The run led it's on and the error led it's blinking.What should I do?
Thank you!
is this an out of the box plc or has the system been powered off for a while?
the blinking light may mean that the internal capacitors are not charged up.
if that is the issue, i cannot remember the procedure to reset the error for this unit. refer to the manual.
james
Yes,those are the connections that I have on the cable,but I forgot to mention that this cable I connected with and male/female adapter and a usb so in the end the cable is like this : RS232male - RS232female - male/female adapter - usb - PC
James,the system has at least 4 years of being shot down.I try now to ressurect it,but from the start I have this problem.Also,I took only the central unit and the power supply on that long mount,without any I/O modules,could be that a problem?I was thinking that it's enough for me to connect with it only with CPU and power supply.
Many USB/serial converters will not work with Omron PLCs. Get one with an FTDI chip set and you may be OK. That being said it is also possible the processor has a problem.
Hi, We have two OMRON C200HG PLC's that control each of our EPG's (Diesel Generators). We understand that these controllers can communicate over...
2,173
Dear All, I’m looking for ways to convert floating point value to BCD for OMRON C200HG CPU43 PLC. From instruction reference of CX-Programmer...
8,895
Hi i would like to get some basic help on PLC Iam using an OMRON C200HG PLC and am trying to connect it with my PC using CX programmer 3.2 ...
7,033
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
135
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
63
