Omron C200HS Power
Maxbeers
Sep 2007
Amarillo, TX
I have a C200HS-CPU01 this has the Power supply and CPU in the same module.
My first question is: Should the power light turn on when 120 VAC is supplied?
My last question is: Is there an upgrade path without having to buy a whole new system?
Thanks in advance.
If I remember correctly, there is a jumper on the power supply screw terminals to select 120 or 240. Jumper ON = 120, Jumper Off = 240. Either way the power LED should be on.
The power supply can be repaired by Omron or others.
You can replace the C200HS with a C200H Alpha (C200HG, C200HE, C200HX) by replacing the backplane and CPU, and adding a power supply, as that is now separated on the C200H Alpha series for the exact reason that you are seeing.
The better long term 'upgrade' is to upgrade to a CS1.
Hello, first off I am not a PLC programmer so bare with me.... We have specialized glass lathe that has a C200HS PLC system that has probably sat...
18
2,183
Saludos amigos. Tengo una impresora comexi modelo FS1500, la impresora usa intouch 7 en Windows 2000, viene con un PLC Omron C200HS, también usa...
1,100
Hello, New to this forum and to Omron. Really hoping someone has some input or advice that I haven't already tried. Have exhausted all I could...
1,407
Hi folks Looking to connect an Omron C200HS to Kepserver using the Peripheral port and the CQM1-CIF02 programming lead. I want to try and use...
1,480
Hi all, I have a few old Omron SYSMAC C200HS CPU01 PLC's and am trying to learn what is req'd in order to communicate with them. I have an...
2,342
