Omron C200HX to CJ1 series
strayplc
Mar 2009
Singapore
Hi..any expert can advise.
I have a old or not very old Omron C200Hx-CPU85z series which I plan to upgrade.
I know CS1 series is the recommended replaced but I am intertested to use CJ1 series as it will be cheaper and modular.
Does anyone knows if there will be any major issue to change to CJ1 series...Thanks
Regards
Stray
The conversion to a CS/CJ will be very similar, if not identical. Obviously the hardware is different, but most of everything else would be the same.
The benefit of using a CS1 in this instance, is that you may be able to re-use the IO modules, just swap the backplane & CPU and your 85% done, surely this would be cheaper than going to a CJ, as the wiring can stay the same....
I can't figure out how CX-Programmer is connecting to this PLC. - C200HX PLC - in the field. - Laptop connected to a network via ethernet cable -...
2,479
Hello, I have a problem with installing Omron DA004 card in the C200HX PLC. In CxProgammer it keeps giving me "Duplex / Special IO Unit...
3,358
Hi guys, do you know if Omron Sysmac C200HX peripheral port supports the FINS serial protocol? Thank you Regards Mike
3,196
Hi guys, I have the following setup Omron Sysmac C200HX connected to a HMI panel using serial port. I need to access some data in the PLC...
8,567
Hi, I have an Omron C200HX connected to Citect. Recently there's a problem with specific data point. The data is received at Citect but at...
2,773
