Omron C28K
scrub71
Jul 2002
Colorado Springs
Can anyone tell me a little about the Omron C28K?
I picked one up cheap and want to use it.
Is there software availble?
Is there a cable that interfaces it with a PC?
Any info/opinons is welcomed.
I would look for another model if I couldn't find a cable for really cheap. Yes there is free software(syswin3.4) you can download but I dont have the address.
The reason that I would not spend a lot on this cable is that the C28 is an old model and doesn't have a lot of functionallity, but enough to learn the basics.
To connect a PC to the C28k you will need a Hostlink as the K model PLC's do not have a serial port. The last time I checked the price of the hostlink it cost more than a new small PLC.
Thanks for the input.
I want to use to to control my train set so I dont need alot of special functions. If I cant find a reasonable cable, is there a handheld programmer? I'm not familiar with Omron's line.
Thanks again
The part numbers for which you are looking are as follows:
Hostlink - 25PIN RS232: 3G2C7-LK201
Hand Held Programmer: 3G2A5-PRO15-E
Both are obsolete. Try ebay. :cool:
c28k
Does any one know where to download the program syswin3.4 I need It for my c28k conroller.
Hello PLCS.net: I have encountered an Omron C28K that lost it's program due to battery failure. Luckily, I had a backup and was able to re-enter...
3,355
Hello! I'm working in upgrading an old c28k Omron to a cp1e. My doubts are concerning the IO pins. I can see in syswin 3.4 the following inputs...
2,485
Hi does anyone know how to clear this error message on the C28K Omron, it say memory error and it will not let me clear it the normal way. I...
4,906
When an eprom (ROHM) is plugged into a Omron Sysmac C28K PLC does it automatically load when the unit is powered up?
1,256
Hi All, We have an old machine with an OMRON C28K PLC. Lately, the said machine is unable to run and noticed that the PLC processor's "RUN" LED...
1,937
