Omron C40h
Marsupilami
Jul 2004
124
Hello,
I have an old C40H PLC here from omron and have found the correct programming software Syswin 3.4.
i can communicate with the PLC and even make a small program work, but now i am trying to set the clock trough the menu in syswin. "Online" "Set clock". then syswin displays PLC: "No clock or bad clock"!
there doesnt seems a way to get around this message. The specifications of the PLC say that there is an on board clock. and if i monitor the special registers i can see a timing value that increases per second.
If i modify the special registers i don't seem to be able to change te clock.
Does anyone have an idea how i should change the clock of this PLC?
regards
Marsupilami
Procedure is detailed in W176 manual:
Must turn on AR21.14 to stop the clock.
Set clock register values:
AR18 MMSS (Minute / Second)
AR19 DMHH (Day of Month / Hour)
AR20 YYMN (Year / Month)
AR21 --DW (00 / Day of Week)
Turn on AR21.15 after all values are set.
this will also turn off AR21.14
Hope this will help.
Hmmm,
I must have misread. i thought i had to Turn ON AR21.14, Set the Clock, And then turn OFF AR21.14.
I will try your suggestion this weekend.
Regards
Marsupilami
Hello All, I have found an old C40H OMRON PLC and want to use it in a home project. since i never used a omron PLC i looking for some advice on...
6,263
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
178
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
70
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
111
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
266
