omron ch200he
ajay34
May 2010
klang
249
:geek:...
hello guys ...i been having problem with omron CPU CH200HE..where the red led
error light is on ..but it not flashing ..it continue steady light ..
i had check present of 24vdc at all input and output terminal..
and also any loosen terminal .but i could not find the problem..
humbley request for any hint or had missed something to check on ..
Go online with the CX-Programmer and check what the error is - it may only be a dead battery but may be worse.
The message show IO bus error..I had even try change cpu itself
But could nit settle the problem..and change then battery itself..
Does this there is problem on inout n output..I even had try isolate
The input and output wire..just left the io unit without any connection
Still gt the same result..
Any other small hint that can help me work out
Could be the rack - try plugging everything in and out several times to clean up the contacts.
Thanks bob...
I did change backplane (io rack) and it works...
But curious coukd backplanes get damage..I dont forse any damage curcuit at it
hai all .. i been working with omron 200HE for some old system .. where by i have 2 spare input module and 3 spare output module.. since alot...
1,857
hi all... :bow: i having porblem to online with c200he omron plc.. recently 1 bought software CX program v.9 ( omron) and GX v.8 for...
23
4,114
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
66
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
197
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
77
