Omron, Changing Operation Mode
lee enfield
May 2012
turkey
Hey all,
i want to change plc's operation mode run to monitor or inverse... but i want to make it via plc programme... when a bit turned on the operation mode goes to run and when the bit turned off, operation mode goes to monitor mode.. how can i do it?
have a look at the SYStem area of the PLC - 65000 area.
I am not sure if it is possible but look there
looks like you can not do it.
As it is possible to be done through CX-one there must be a way but probably not through a Bit
BobB may have the answer when he is online
I am not aware of a way to do that. I fail to understand why you would want to do it - I normally leave the PLC permanently in monitor mode - same as run except you can do online programming and write from a SCADA system or the like in monitor mode.
I do remember many years ago there was a way devised by Citect to change a PLC to monitor mode as in those days it was not possible to have an Omron PLC start up from power up in monitor mode - they always went into run - these days you can select monitor mode in the setup.
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
325
If I post a .cxp program that controls a centrifugal separator, would someone be willing to take a look at it and tell me what memory address I...
2,736
I want to use a Digi One-IAP to provide Ethernet connectivity to an Omron CJ1M. The RS232 port is connected to an HMI, but the Peripheral Port is...
4,630
Hello , I want copy a changing value from analog input to registers . I want to do this for example every 1 ms , and store this samples...
4,827
Hi, folks! First post..... My background is in Mainframe programming (20 years), but PLC programming is a whole 'nother animal, it...
6,740
