OMRON CJ2H DeviceNet and IO addressing
pawelleg
Mar 2004
Tianjin
Hello Everybody!
as I will have to face project based on Omron PLC and not being very familiar with hardware I would like to ask you for some advises concerning system configuration.
First some facts:
Main and the only rack is filled with CJ2H CPU65-EIP module and 5 x CJ1W-DRM21 for DeviceNet. The first DRM21 module will be connected with Safety DeviceNet with 2 Safety controllers and some Safety IO units on it.
Questions:
1. how to configure DeviceNet networks - using Safety Network Configurator for all 5 networks or maybe just for the first one(Safety network) and rest should be configured via CX-Integrator?
2. how about IO mapping in PLC? How shall be addressing created concerning 5 DeviceNet networks - is auto allocation mode useful in that case? How I will assign addresses for all remote units in PLC program?
3. Symbolic table - is there any way to import addresses with their comments for simple and quicker symbolic list assignment?
That would be all for now ;)
I will appreciate your suggestions!
Use CX-Integrator and move to whatever memory area you wish. Alternatively, when you set your card addresses and create an I/O table in the PLC, upload the I/O table and your address areas will be shown on each card.
Create in Excel and simply copy and paste into CX-Programmer symbol table. If some symbols are duplicated or incorrect CX-P will pop up a window to allow you to correct them.
You can also just copy and paste from CX-P to Excel in the same feshion. you just have to adjust the cell type in Excel to accomodate the I/O addressing for things like 250.00. 250.01 will import OK anyway.
BobB, thank you for your advice (y) !
I have managed symbolic handling via excel already ;) and for configuration i have decided to use one tool only, i hope it will work.
I have 2 cameras set up on one of our production lines. Both cameras are fz3 omron cameras communicating to a CJ2H Omron PLC through a 232C. One...
1,558
Dear Members, I'm try google and search Web Server Module Omron for CJ2H series CPU, but fail t get the model code. For Mitsubishi, their module...
3,388
currently we use 2 CJ2H PLC to do software redundant and link to one hmi. PLC 1 address(primary): 192.168.2.1 PLC 2 address(secondary)...
1,524
Hi Friends, I hope someone out there can help solve a problem I'm currently experiencing with converting a PLC program from one Omron CJ2H CPU...
3,081
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
70
