Omron CJ2M
May 2015
ohio
I am unable to connect to the front port on an Omron CJ2M plc. Its IP is set to 10.72.85.18 and the subnet mast is set to 255.255.255.0. It is not indicating any faults. Is ther something other than this that needs set?
Its IP is set to 10.72.85.18 and the subnet mast is set to 255.255.255.0. It is on a network and resides on a segment differetnt from the pc I am attempting to connect with.
Unless you have some magic going on in your network switches / routers, you will need to get your PC on the same network - specifically you will need to set your IP address to 10.72.85.yy (something other than .18 and not something used already on the PLC network) with the same subnet.
All right, let's take a step back...
What is the IP and mask of the PC? If it is not 10.72.85.SomethingOrOther, then you must change your Network Settings to put you on the same logical network as the PLC.
EDIT: Dan beat me to the punch... ;)
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
206
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
86
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
147
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
127
I have a project to control the speed of motor DC using PWM Output on PLC and when im on working i have a several trouble and of of them is the...
252
