Omron copy D memory area old cpu to new cpu?
S1ack
Sep 2023
NC
Project involves updating a ~23 year old controller (C200HX CPU64). The HMI is a windows NT machine with the gui done with Delphi 5 (Pascal)
communication via SYSMAC library.
Replacement is CJ2M CPU15 with devicenet and enet modules. New gui is Ignition using FINS driver. Working.
All HMI <-> PLC traffic is the D memory area. I'd like to snapshot the 'DM' area (all of it) from the old CPU, and write into the new CPU 'D' area.
Possible?
If so, any insights appreciated.
Go online with CX-Programmer.
Choose Memory on the left.
New window will open, choose D from the list of areas
Make sure you are online and the values are populated in the spreadsheet view.
Go to File pull down menu, Save to File and it should create a file with the values.
Then you should be able to Import the File into the new processor.
Hope this helps,
gtsuport
Hello , I want copy a changing value from analog input to registers . I want to do this for example every 1 ms , and store this samples...
4,826
Good morning everyone I’m currently working on a omron device net and have a nord drive that fell off the network. I have limit knowledge in...
148
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
87
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
216
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
88
