Omron CP1E High Speed Counter Programming
riyajahamad
Jun 2002
Pune-India
133
Dear PLC Experts,
I am programming Omron CP1E. In High Speed Counter application, in earlier version PRV (67) function used but now PRV (881) is available. DM flags also need to change with D.
I am getting Hex value in First Destination word, I need decimal value.
Is anywhere needed to set the same?
I searched in related manuals about the same but no success.
Am I needed to use Hex to Decimal Converter? Same also not found in instruction list.
I am using CX-Programmer Version 9.01.
Thanks in advance.
Riyaz,
Pune, India
Can you not just read the location where the counter is Axx? I don't have any information on the CP1E, but in the CP1L it is A270 - A273 for HSC 0 & 1.
Are you sure, what mode are you monitoring in?
Damn, I must check for updates!!
Hello. I have a problem with omron sysmac cp1e controller delayed start. The controller has been working on the punch press since 2016. Recently...
766
Hi, I need to communicate omron CP1E PLC with SCADA to get the status of the machine. There is no etherent port available but an empty expansion...
1,612
Hello... I remove one CP1E from old useless machine and I would like to use it with something else....but it is locked/have no pass/....How can I...
1,451
hi all i have used a real time clock to turn on a bit after 1 month. the plc was off for this whole month and when i turned on the plc after a...
1,427
We had a CP1E go bad (power issue). Installed spare and could not get it to communicate to our motion drive via add on RS485 card. Tried...
1,509
