Omron CP1E-N40SDR-A Input Allocation
Thor Hammer
Jan 2014
Santa Cruz, CA
36
Setting up the PLC in my title. CP1E with 40 I/O.
0.00-0.011 are OK and show up as In
When I input address CIO 1.00 (24 inputs) it shows up as a Work bit. I double checked my PLC selection as CP1E and N40 and all OK. Not sure why its doing this.
Outputs are same. I type in 101.00 and it shows up as a work bit. Yet 100.00-100.07 are ok.
Any insight greatly appreciated!
Interesting. See screen shot below.
I am running CX-Programmer v9.61.
I would contact Omron tech support (800-556-6766) and ask if they are aware of any issues.
I just tried it again on v9.63 and this time it worked correctly. That's really STRANGE!!
The first time I defined the symbol "ONE" for 1.00 then set the CPU type. The second time I set the CPU type before I defined the symbol.
I just got off the phone with tech. I don't know why, but when I opened a new project 1.00 shows as In.
However, opening a previous project with a different PLC, then updating the PLC and saving as a different file name did not allocate the inputs correctly. Odd, but ok. Problem solved. However, I closed my project, then re-opened it. THEN, it allocated correctly. Hmm, ok.
Hello. I have a problem with omron sysmac cp1e controller delayed start. The controller has been working on the punch press since 2016. Recently...
769
Hi, I need to communicate omron CP1E PLC with SCADA to get the status of the machine. There is no etherent port available but an empty expansion...
1,616
Hello... I remove one CP1E from old useless machine and I would like to use it with something else....but it is locked/have no pass/....How can I...
1,458
hi all i have used a real time clock to turn on a bit after 1 month. the plc was off for this whole month and when i turned on the plc after a...
1,434
We had a CP1E go bad (power issue). Installed spare and could not get it to communicate to our motion drive via add on RS485 card. Tried...
1,519
