OMRON CP1H same program not working
kmarsus
Jan 2013
Dhaka
Dear Omron experts,
I have omron PLC in my machine. Model: CP1H.
I have bought a new one for spare the PLC.
So, I have uploaded the software from old one through CX-One software and downloaded to new one.
Everything work fine with new PLC but one Solenoid valve is not working. I have tried many ways. I have again install old one it's fully working but when I install new one with same program only that particular solenoid valve is not working.
My both PLC are looking 100% same and the program also 100% same.
Can anyone suggest me where is the problem?
( I have attached my program here.
For program: line 52 and 53 output: 101.00 and 101.01
is responsible for the solenoid coil that's not working properly)
You copied the program, but I am pretty sure- not the data memory.
There are H100, H110, H120 words for timer set values.
Copy there the values from the source PLC.
Dear, I see H100, H110, H120 is high speed timer.
Can anyone tell me what is the difference between High Speed timer and normal timer?
Dear,
How to copy the value of H100, H110, H120.
Can you please tell me a little bit more details.
Can you force these outputs on?
When you uploaded the program did you tick upload memory as well? Without knowing these values you would have to manually enter a value.
If you don't know the value why not just manually enter a value into the H register and see if you can get it going?
Hi all, I have to say first that I have no experience with Omron devices, but here's the challenge that I'm facing. I have an Omron CP1H...
1,709
I have a question about SET instruction in Cx-programmer. When condition goes true it is supposed to give value 1. But, my controller is giving 0...
24
2,289
Hello Sir/Ma'am, Hope you and your family are safe in this Covin-19 Pandemic. One of my client have a machine in their ceramic industry which...
2,618
Hi, I recently had to buy a batch of new electrical components containing 10 PLC Omron Type (CP1H-X40DRA) Apparently stored in store (to be used...
3,551
Hi, i'm using cx programmer 9.5 running on my vmware and trying to connect to my CP1H- XA. I did the required driver installation suggested in the...
2,850
