Omron CP1L-E Function Block for Scaling
b4umusic
Jan 2012
toronto
Hi All Omron Experts
I need help to create a FB for Omron PLC CP1L-E
Task: Detect and Monitor Oil Level in a Hyd. Tank
Using Incorporated Built-In 0-10V Analog Input 1(PV Register A642)
Scaled Value: 0 to 100 (0V=0 and 10V=100)
Levels to be monitored: Low, Medium and Okay)
Turn Bit W10.1 when oil level is low (0 to 30)
Turn Bit W10.2 when oil level is medium (30 to 60)
Turn Bit W10.3 when oil level is okay (60 to 100)
Hi everyone! I have an issue with some Omron CP1L-E PLC's. They're connected to get the info from production machines, but I've noticed that...
1,158
Hi! Omron CP1L. CX Programmer. How do I fix so that a CNTRX(548) remembers the count it had before a power failure? I need to know how many...
1,400
Hi! Newbie here... Cx-programmer CP1L PLC NB7 HMI I want to multiply something i by 1,5 in CX-Programmer to get a higher number to use in HMI...
2,244
Hi all, I've been upgrading some machines recently which involves installing a 10" NB HMI, HUB and a CP1L-E to avail of the built-in ethernet...
1,707
Hi, is someone experiment connecting a Omron plc CP1L with a Siemens HMI TP1200?, i've installed the drivers in WinCC , plc options is just CS1 or...
1,916
