Omron CP1L PLC: How to get current PV of timer and counter?
cch
Jun 2011
Selangor
Hello,
Does anyone knows how to get the current PV of the timers and counters for Omron CP1L PLC?
That would be great if can have some examples.
Thanks a lot.
Move the Timer/Counter Number to the desired location.
MOV T0 D0 Moves current value of Timer 0 to Data Memory DM0
MOV C11 W14 Moves current value of Counter 11 to to W14
Hello, I have an installation with an omron plc CP1L with a CJ1W-CIF12 module connected to eight omron MX2 drivers. I use the bus to modify the...
2,161
Good afternoon, I need to create a recipes display on the hmi ns8, to change the parameters of a servo and some strings . The PLC that im using is...
2,777
I have a problem with my machine....we are using Omron CP1L PLC with a set of temperature controllers and Hakko HMI to control a set of 16...
2,356
In the hand position: Pumps 1 and 2 are controlled and alternated by the hand selector switch. When Hand position is first selected, pump 1...
3,606
Not able to connect to OMRON CP1L-EM PLC, I want to restore factory default ethernet address settings and port settings. Please suggest how can I...
2,278
