OMRON CP1L RS-485 ASCII TXD/RXD sample?
strantor
Sep 2010
katy tx
401
Howdy. I've got a CP1L here with CP1W-CIF11 RS-485 interface module installed and I'm trying to teach myself how to transmit ASCII data, so far unsuccessfully. The ultimate goal is to transmit ASCII commands to a stepper controller, but right now I have the output going into a RS485>RS232 converter --> RS232>USB converter, and trying to monitor any data transmitted by the PLC in a serial terminal window when I close input 0.07. I'm not getting anything.
Does anybody have some guidance for me, or perhaps a sample program that I dig through to figure it out?
Thank you.
You may need to modify the value of the control word.
You did not indicate which CP1L you are using, or in which option slot the CP1W-CIF11 is installed.
You will also need to properly configure the port under the Settings option in the Project Workspace. ASCII would require the setting be to No Protocol.
Hope this will help.
Hi everyone! I have an issue with some Omron CP1L-E PLC's. They're connected to get the info from production machines, but I've noticed that...
1,175
Hi! Omron CP1L. CX Programmer. How do I fix so that a CNTRX(548) remembers the count it had before a power failure? I need to know how many...
1,405
Hi! Newbie here... Cx-programmer CP1L PLC NB7 HMI I want to multiply something i by 1,5 in CX-Programmer to get a higher number to use in HMI...
2,262
Hi all, I've been upgrading some machines recently which involves installing a 10" NB HMI, HUB and a CP1L-E to avail of the built-in ethernet...
1,713
Hi, is someone experiment connecting a Omron plc CP1L with a Siemens HMI TP1200?, i've installed the drivers in WinCC , plc options is just CS1 or...
1,921
