Omron CPM1 Clock Function
Clueless
Guest
C
I know the CPM1's are a bit outdated, but it is all I have to work with. I am looking for information concerning a clock function which would allow me to turn on and off an output at 2 hour intervals. I can't find anything in the manual so any suggestions would be helpful.
Thanks,
Clueless
The CPM1 does not have a real time clock, so there will be no synchronization with real time. If all you are after is a 2 hour timer than use the following circuit.
| 1 Minute Clock
| 25400
|----| |----------------[ CNT]-|
| CNT 000 [ 000] |
|----|/|----------------[#120] |
:p
Thanks for the reply. I just want to confirm that your circuit will be on for two hours and off for two hours. Then on again and so on.... (I am a mechanical engineer who's PLC guru is on vacation. I am a novice at this stuff!)
Thanks again.
Jay, I think the -]/[- was a typo? Should be -] [-, right?
Even with this fix, Jay's counter (pseudo timer) will simply recycle every two hours. Or am I missing something Jay?
Sorry, but I don't have any Windows-based Omron software, else I'd give you an example (I can't cut/paste to here with my DOS stuff)
Maybe Jay will be nice and post another listing now that he knows the 2-hour ON/2-hour OFF requirement?
In the mean time, take a look a the flip-flop thread (if you can weed through our tangents!). You can use Jay's counter to trigger a flip-flop, toggling your output every 2 hours.
-Eric
Yeah, you're right. I was thinking about a free running timer.
You could use a flip-flop but using cascaded timing circuits allows for separate on and off times.
I would post screenshots, but I don't know what ladder package he's using from Omron.
Try this circuit for 2 hours on/ 2 hours off. :rolleyes:
| 1 Minute Clock
| 25400
| CNT 001 [ 000] |
|----| |----------------[#120] |
| 1 Minute Clock
| 25400 CNT000
|----| |-------| |------[ CNT]-|
| CNT 001 [ 001] |
| Timed Output
| CNT000 01000
Thank you both Jay and Eric. I will try out the circuits and if the (pardon the pun) "ladder" doesn't work I'll let you guys know.
Clueless
On second thought Jay, I may need the screen shots. We use SYSWIN 2.1 programming software from Omron. Would this be the info you need to post a screen shot?
I'm taking some time today to learn how to edit a customer's Omron PLC program. My customer has a machine that is used infrequently during the...
2,863
Hello there! i need some help regarding omron plc the CJ1M and CPM1, do they have the same software and connecting cable? and which of the two is...
2,747
Today i try do upload the program, but when click ok the programe tell me the program is protect, i need the pasword but i forgeret,
1,373
Hy, guys I need to know how make contactor retencion? For examplo If i push switch for input 00 and active 00 out but i need how make if i push...
2,786
I have software fore omron cpm1, this software kork whith cpm2. I need help guys tank you.
2,525
