Omron CPM1A 30CDR
isteak007
May 2009
NewYork
216
Hello,
i cannot communicate with CPM1A 30CDR But
But with the same cable i can communicate with CPM1 Sysmac.
i have three (3) pcs CPM1A 30CDR (AC) i can not communicate with any of these series PLC. PLC is fine
Why i can't communicate?
i am using cx programmer v9.0
What exact manufacture and model of cable are you using to try and communicate? Are you using a real Serial Port or USB Adapter? What Operating System and Service Pack are you using?
Stu.....
Stu.....
Cable is made by Omron CQM1-CIF02
I am using real serial port
OS: Windows XP SP2
Cable is OK (RS232<->Peripheral Port), there should be no problems.
Maybe you need to chech you communication ('network') settings while connecting to CP1MA or CQM1-CIF02 cable is damaged.
Check with Auto online
Auto online Option is there to connect with the PLC
Because Baudrate may be different in PLC, By using this option Software will automatically check for the baudrate.
I've got an upload from an Omron SYSMAC CPM1A PLC but I cannot figure out for the life of me how to document the inputs and outputs. It's version...
3,307
Hi, I have recently purchased an old Omron Cpm1a plc to practice on. I have a version of syswin that does not require a licence to program these...
1,674
I have a Omron PLC with CPM1A-MAD01 anaolog input output module its reading pt100 temperature probe. When the machine is running it starts to...
1,101
Hi, I have recently being using a Omron CPM1A-40CDR-D-V1 and transferred an old program on it. I was testing the program and making some...
4,262
I have two of the same units that are using a CPM1A and an NT20S-ST121B-EV3. I am not able to connect to the touch screen as far as i can tell via...
4,014
