Omron CPM2A question...
Feb 2005
Greetings,
This is my first post to the group. Good to see it here.
I just started a new job that uses Omron PLCs which I am not familiar with. I haven't had any training, but have managed so far. However, I'm having a problem getting a handle on a couple of things.
The foremost is/are the, for a lack of a better word, internal clock flags (i.e. 254.00 - 1 Minute Clock Bit, 255.00 - 0.1 Clock bit...etc.) Where can I get information about these bits?
Immediately, I'm consolidating a couple of programs into one and I'm trying to understand the programming. With these bits, specifically 254.00 the 1 minute pulse, are these true for 1 minute, false for one minute, or what? I'm getting confused with the way they are used in the program and would appreciate some assistance.
Thanks,
Ralph
CPM1A/CPM2A/CPM2C/SRM1 Programming Manual @ omron.com
All the Omron clock bits are 50% duty cycle. For instance, 254.00 (1 minute clock) is on for thirty seconds and off for thirty seconds. 255.02 (1 second clock) is on for 0.5 seconds and off for 0.5seconds.
Thanks a bunch. I got the link to the programming manual.
I did a search for the bits in question, but couldn't find them. Do they have a specific name? What are they called that I might be able to find them.
I've had over 15 years of PLC programming experience (10 of AB's back when the PLC5 and the PLC3 were the cat's meow...) but I haven't had any real experience with the Omrons. I've read parts of a programming manual and can generally keep up, but I'm trying to dig even deeper.
Thanks,
Ralph
Hi, I have a CPM2A PLC setup for a machine. There is an rotary incremental encoder connected to the PLC at input 0.00 (A+ terminal of encoder) and...
4,089
Hi all, My name is Firdaus. I am a teacher. And for the next semester I have to teach PLC to student. The problem is, I just move to this school...
1,997
Hi Folks. I have a problem with an Omron CPM2A-60CDT1-D High Speed Counter. It had been working well, the problem arose when a very minor program...
1,467
Hi Folks. I have a problem with an Omron CPM2A High Speed Counter. It had been working well, but the problem is that a program change was...
1,377
Omron's CPM2A has a compact flash card slot. Can an Omron program simply be copied to a compact flash card using a Card Reader or must it be...
1,522
