Omron CQM1H-CPU21 need help
Towerlight
Mar 2007
NYP
24
Hi All,
I'm having a problem in connecting my laptop to the Omron PLC.
I have the RS232 cable from Omron but my laptop don't have the RS232 Port so I'm using the USB to RS232. I try to go online but it say connection fail. Sorry, i don't know much about PLC please help...
Here are some keys to success.
1. Make certain that the drivers for your USB converter are installed. Use the Windows Control panel to determine which COM port is assigned to your adatper. You can use non-Omron adapters, and many do work, but not all will work.
2. Make certain that you have the correct RS232 cable.
3. Turn DIP Switch 5 on the CQM1 to ON. This will configure the PLC port for Host Link protocol, 7 data bits, even parity, and 2 stop bits ('standard' Omron settings).
4. In CX Programmer, make the same settings for communications, and you should be able to communicate.
If this does not work, is there anything else that we should know about the PLC? Is it working, any Error / Alarm LEDs, etc?
Hello, i have a omron plc with cqm1h cpu, and is protected by um read password i need any program to crack it lik xtal, plc backup tool v6 with...
1,075
Hi. I work for an industrial machinery merchant so we have to try to get uploads from all sorts of different PLCs & HMIs. Our latest victim is an...
5,640
Hi, I am new here, and hope if there is any things I done wrongly, please feel free to tell me. Thanks in advance. Currently, I am deal with PLC...
2,878
Hi, i have been given the task of measurring temperatues of a certain cooking chamber in my factory...they have a plc omron cqm1h-cpu21. My boss...
2,650
I want to download the program to the PLC Omron CQM1H-CPU21 using RS232, but an error message appears Dip Switch settings are wrong, therefore how...
7,774
