Omron CS1H CPU Cycle Time Error
minaykha
Apr 2009
singapore
96
Hi Everybody,
I am using Omron CS1H CPU in one of my project.
There are five machines using same CPU, same program and same design ( meaning 5 duplicated machines )
But, one out of fives machines frequently trigger the
cycle time error alarm and machine stopped when this alarm trigger.
As CPU series is same and program also same, i cant find out
why this cycle time error happen and where the problem come from.
Dose anyone has any suggestion or similar experience ?
How can i fix the cycle time error alarm ? Thank you.
I just want to share the info.
Problem was HCA tool switch.
I put the HCA tool switch to OFF position, after that, no more cycle time error.
We have 2 same machines ,The PLC is omron CS1H-H ,CS1W-MC421,One machine the cpu broken ,Then I replace a new cpu module,use the CX-programer and...
2,006
Does anyone know what the maximum limit of I/O is for the Omron CS1H-CPU67? I think it is 10,240 (5120 local and 5120 remote) but having a hard...
2,249
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
145
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
63
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
102
