Omron cx programmer keep
T Gibbs
Jun 2012
Morristown, TN
406
Hi, I am just starting with CX Programmer. I normally use RS Logix, Proworx, Directsoft-5, Click, etc. In looking at the available instructions I notice a SET and RESET instruction and a KEEP instruction. I do not see the difference. Can someone enlighten me? I know how SET and RESET work as I use them in Directsoft. The only difference I see is that KEEP is all done in the same network where SET and RESET would be done in separate networks.
The Set and Reset Instructions in Omron do pretty much what they sound like. They Set the Bit to 1 or Reset it to 0. Once the Instruction has executed, the Bit will retain that Value regardless of the state of the Rung. They do not have to be in separate Networks.
The Keep Instruction is more like an Allen Bradley Latch and Unlatch Instruction, but combined into a single Instruction.
See the Instruction Help in CXProgrammer, or the Instruction Reference for you CPU.
Stu....
just to make it more complex you can address a keep relay and set/reset with the same designation.
Omron Help shows the Keep example for operating a toggle button (flipFlop)
so it can be done easily on the one network
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
384
I am using a function block that has a in/out parameter that is a structure. The structure has an array as one of the elements. I can index the...
745
Is there a way in CX-Programmer to call Ladder Instructions from a structured text program? I can see several functions in the autocomplete...
1,986
Is there a way in CX-Programmer to call functions from a structured text program? I have found this manual that seems to describe the process...
1,069
Is there a way in CX-Programmer to initialise an array? Set all values to zero or false depending on the data type Solutions in Ladder and...
1,300
