omron cx-programmer not initializing
vimalp
Aug 2004
hi all,
I'm new on this forum! if i'm posting this question @ wrong forum please excuse me!!
We are trying to initialize omron plc cqm-1h cpu2 through cx-programmer, But its not working!
Could you please shade some light on this please?
Initialize??? Does this mean connect to or restart or what?
If connect to, what cable are you using? Did you buy it or did you make it yourself? What error is CX programmer showing?
it is working now
hi all,
Its okay now, we re-configure connection and try to change databit to 7 instead of 8 and com2 instead of com4
thanks anyway!
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
397
I am using a function block that has a in/out parameter that is a structure. The structure has an array as one of the elements. I can index the...
756
Is there a way in CX-Programmer to call Ladder Instructions from a structured text program? I can see several functions in the autocomplete...
2,008
Is there a way in CX-Programmer to call functions from a structured text program? I have found this manual that seems to describe the process...
1,082
Is there a way in CX-Programmer to initialise an array? Set all values to zero or false depending on the data type Solutions in Ladder and...
1,313
