Omron Cx Programmer question
tadams73
Nov 2008
Tennessee
25
When I pull up some of by backup files using Cx Programmer 6.1 and try to go online I get a pop up saying "Modem Port Has Been Selected.Do You Wish To Continue".I can go to some previous backups and it works fine.Its been doing this more here lately.These backup are from as far back as 2005 and as new as last week.Im stumped.Thanks.
You didn't mentioned how are you connecting, anyway
In Offline mode -> PLC Properties -> Network Type -> Settings - under the modem tab select none [just a guess only, explore on this]
Its using a comm port assigned to the modem this is normal problem in that when the software gets written the first time it will set the port to whichever was used to transfer the program to the PLC originally. if you go to the project tree on the left. right click the processor symbol you should see change as an option. change your comm port assignment. Doube check which port your USB is currently using if your using a USB converter
When I bring up a program using CX programmer, the program comes up and all contacts have names on them but no I/O address. Is there a way to get...
3,527
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
379
I am using a function block that has a in/out parameter that is a structure. The structure has an array as one of the elements. I can index the...
738
Is there a way in CX-Programmer to call Ladder Instructions from a structured text program? I can see several functions in the autocomplete...
1,974
Is there a way in CX-Programmer to call functions from a structured text program? I have found this manual that seems to describe the process...
1,062
