Omron Cx-programmer v9.43 Swap(637)
Tommycai
Aug 2011
KY
120
I am bringing in a string to a W address area, from a camera, then swapping the bytes and transferring the values into a D address area. How can I be sure that this has transferred?
I did an erase value in an auto sequence made before, but sometimes it missed the erasing block and just incremented to the next block until i put into the line check to make sure the block is zero.
Am I too worried or is this a possibly occurrence?
Not sure how to post code but this is all supposed to be in the same step.
Step = #-------------------------------Swap(637)
&6
W408
-----------------------------------Xref(070)
#6
W408
D200
-----------------------------------Mov(021)
Next Step #
That should work as long as your step number changes immediately but I suggest that you use @SWAP and @XFER so that those instructions can't execute twice.
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
395
I am using a function block that has a in/out parameter that is a structure. The structure has an array as one of the elements. I can index the...
754
Is there a way in CX-Programmer to call Ladder Instructions from a structured text program? I can see several functions in the autocomplete...
2,003
Is there a way in CX-Programmer to call functions from a structured text program? I have found this manual that seems to describe the process...
1,078
Is there a way in CX-Programmer to initialise an array? Set all values to zero or false depending on the data type Solutions in Ladder and...
1,313
