Omron Ethernet/IP to AB Point IO
AndrewY
Oct 2007
Auckland
I'm trying to connect an Omron PLC (CS1, via an EIP21 card) to some Allen-Bradley Point IO (1734-AENT).
I have been using Omron's Network Configurator tool to set up the network and can happily see the two devices that I want to communicate together.
I have installed the latest eds files for the 1734 series, and configured it to match what we physically have (i.e. 2 slot chassis, slot 0: AENT header, slot 1: 1734-OB8 output).
I am able to download this to the Point IO device ... however whenever I upload it the device is saying that it has nothing configured in slot 1.
The other thing that I'm concerned about is the settings required for the number of Input and Output bytes to the Point IO device. I am currently trying an output size of 10 bytes, and input size of 14 bytes.
Any ideas?
cheers
Open up a web browser to the actual Point IO AENT module.
You MUST set the chassis size there, through it's own web interface, it won't take a download from anywhere else.
Very annoying.
I have a strange Kepware issue I have been dealing with for a few weeks. I have Kepware setup with the Omron NJ Ethernet driver and reading in...
98
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
362
Has anyone had success communicating between the Avery ZM series of weight indicators and Omron CJ PLCs? I can easily do setups when provided...
327
Hi Guys, I am trying to read data from Omron CP2E CPU from my Mitsubishi RJ71EN71 with Simple CPU Communication Function. Suppose it was using...
1,812
I can't figure out how CX-Programmer is connecting to this PLC. - C200HX PLC - in the field. - Laptop connected to a network via ethernet cable -...
2,478
