Omron Fatal error 0x80F1
moosstock
Apr 2015
San Antonio
Please see the attached photos. I was trying to transfer changes that I had made offline to the PLC that was online and then my communication stopped. Once I got it back up This is what I saw. Anyone help?
Regards
Moos Is Loose!
PLC Central Memory error1.jpg PLC Central Memory error2.jpg PLC Central Memory error3.jpg PLC Central Memory error9.jpg
The first error usually7 means there is a password on the UM area that needs to be entered before downloading but could be a memory error.
The second error also mentions memory error - not sure what this means - have never seen it before. I/O verification error possibly means that the I/O table you have in your software has been downloaded to the PLC and it is different to the actual PLC configuration. Place in program mode and create the I/O table - this may even clear some of the other errors.
Do not know about the third one.
Were you able to clear the memory error with the fourth one?
The meaning of the error codes can be found in the manual - the best place to start.
I have an Omron CQM1H PLC that keeps having a reoccurring error. In CX Programmer I read the error as "FATAL I/O". I usually just power it down...
1,465
so I have a omron CJ2M-CPU33 with a serial Port card adapter plugged into it. I am getting this non-fatal error and would like to resolve it it...
5,225
Hello to all We had an Over voltage power and 3 expansion cards connected to the plc were broken; and the plc showed the fatal error(POWER led is...
9,285
Help! I'm not too familiar with Omron. I would like to know if there is an easy way to locate where the problem is in the program? I converted an...
7,995
A
Hello, I’m having a lot of problems opening programs from Omron SP20 PLC Using the Omron MINI LSS 1.2 software. I have had a lot of experience...
12,311
