Omron Host Link question
PLC_4_Ray
Jan 2016
Portland, Maine
I have an Omron Sysmac C28K PLC with a 3G2C7-LK201-EV1 Host Link Unit on it, I am able to connect with SYSWIN 3.4 without issue. I also have an Omron Sysmac C20H PLC, it does not have a Host Link Unit on it, I power it up and have no errors, to use the 3G2C7-LK201-EV1 Host Link Unit, the manual call for using a console adapter C200H-BP001 or C200H-BP002, it seems like this is only so the 3G2C7-LK201-EV1 Host Link Unit can be secured with screws, I am able to plug my 3G2C7-LK201-EV1 Host Link Unit in directly, but I get an error LED and I am unable to connect with SYSWIN, I get a SYSWIN Communications Error “No response from the PLC”. My questions are 1. Do I need the console adapter C200H-BP001 or C200H-BP002 or should the 3G2C7-LK201-EV1 Host Link Unit work plugged directly into the Omron Sysmac C20H PLC? 2. If 3G2C7-LK201-EV1 Host Link Unit should work plugged in directly, what do I need to do to get SYSWIN communications working? Any help is very much appreciated, thank you.
The C20H uses a different Host Link unit.
The 3G2C7-LK201 is only for the C20 flat pack and C**K units.
C20H would use Host Link 3G2A6-LK201-EV1.
Just a heads up, the C**H units were discontinued in 2002.
Hope this helps.
I have put together a post to read memory areas from the Omron PLC using VBA. This is a serial communication using (Sysmac Way) Host Link...
2,937
Has anyone done any reverse engineering on the Omron Mailbox (MB) command? There are a few things I want to do, such as upload program only, that...
1,599
I have a project to replace an old Omron #3G2C7CPU74E unit with a newer type. The equipment is still in operation. I have no documents or drawings...
17
10,465
I need the details of the host link command :MB . Can anyone help me ? Thank you !
4,517
R
We are trying to communicate serially to an Omron C2000h via Host Link with GE Fanuc Cimplicity Plant Edition Ver 6.1. We can read DM memory...
5,459
