omron instruction
yazan83
Oct 2007
Damascus
20
I'am working on omron CQM1H ,an error appears when i use differentiate Up down for the contact,i want to activate the set and reset instruction on cantact rising edge .what can i do ?
thank u for help
As gtsupport stated, the differentiated contact is only available on the CS1/CJ1 processors.
On C series you can use the DIFU or DIFD. This is how it works.
This:
Would be the same as this:
acually c-series OMRON they have DIFU and DIFD intruction or you can use @set or @reset.. if you use CX-programmer software you can find how to use that instruction from help button
Yazan83 you should check you original post on this question as we have already provided the answer on your C-series post
http://www.plctalk.net/qanda/showthread.php?t=34531&goto=newpost
Hallo to everyone. I have an OMRON C28H plc with a monitor ( you can see attached foto) which is from an old marble polishing machine. I do not...
2,207
Hello fellow enthousiasts, I having a small Structured Text problem on an Omron CJ2M using CX-programmer. I’m trying to use an SHL instruction...
2,244
Hi all, I am fairly new to PLC programming, and just have a simple program regarding an unlatching input. In the picture below, I have STARTCOIL...
3,259
Hello Guys, a pleasant day to you. I have an Omron C40K plc unit, which is to be replaced with CP1E. On the program file, I came across an...
2,412
anyone can help me with snxt and step commands? can we place snxt and step at same rung? please give me an example, thanks. :)
1,595
