Omron NB5Q-TW01B web browser
forqnc
Jul 2009
Elizabeth City
148
I've spent the last few months researching various remote software to HMI. What I am trying to finally get to is using an intrinsically safe tablet, running windows 10, to be able to view and change values with (currently) an Omron NB5Q. Today I stumbled on this link
https://www.myomron.com/index.php?action=kb&article=1660
regarding being able to set bit LB9175 on the HMI and I should be able to connect via a web browser. So I have the bit set, using explorer 11, I was able to connect with my PC. Then I went to my office and got the tablet, I'm not real familiar with win 10, but it appears Microsoft Edge is it's browser. No joy, could not connect, went back to my PC and it was timed out. Every time I try my PC now I cannot connect.
Anybody had any luck using the web browser?
OK, so I've got my PC back online but not the Tablet still (helps if you verify the LB9175 bit is really on :oops:)
I'm wondering if it is Microsoft Edge preventing, since google won't work either.
Hey all. Have a Omron NB5Q HMI, looking to integrate a handheld RS232 barcode scanner to input codes. All well and good for the numeric input...
2,287
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
178
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
69
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
111
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
266
