Omron NJ and LinMot - Anyone?
Lamboom
Mar 2014
Fallbrook, Ca
350
Thanks to many people on this forum, and automation engineers in in several countries, not evolved with this forum, I have been able to almost finish a long project which uses the NJ and an NA HMI to manage LinMot linear motors. However, Omron doesn't seem interested in working with LinMot .. Omron already has their own linear motors. LinMot isn't real interested in the Omron systems controlling their drives and motors, they have a relationship with Rockwell. In spite of this, the two systems do work well with each other, both Ethernet/IP and EtherCAT LinMot Drives will interface with the NJ, even while also using Omron Drives and motors at the same time. There is no one in the Omron court that I know, who builds machines using LinMot ... soooo, I'm asking the forum for any contact information of someone you know, that does.
PS: this is a bit dated .. but it shows one early application: https://www.youtube.com/embed/B0UGm9JTw3U?rel=0
Note... The main control system is Delta Motion's motion controller RMC75E-QA2 and two LinMot linear motors (which work great!) I did also research an Omron system (video) .. and cannot "Immediate Stop" the LinMot drive with an NJ Error or Fault. Would like to fix that.. :)
Thanks much, Regards, Michael Lambert
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
174
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
110
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
258
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
144
