Omron NJ - FINS Communication
chelton
Jan 2012
melbourne
325
Is there a problem with the NJ processor and FINS communication?
I created a new project with a Variable "myInt" Array[0..100] Of INT with AT set to %D10 as shown
I can connect with citect using the OMFINS driver and read/write to D10 - D100
BUT
I can also read/write to areas outside of this range say D0 or D200 and cannot find the affected memory areas in sysmac studio.
This seems dangerous if I could potentially overwrite other memory areas.
Hello there, I am new to OMRON PLCs so need some help to communicate two PLC over FINS Protocol. Here are the description of the system...
1,049
Hello, We have to create a communication between Cimplicity V8.0 (PC W7 64 bits) and an OMRON CJ1 PLC with Fins Ethernet Protocol. We've tried...
5,743
A
how to write motor position variable trought motion card (mc) using fins command. now i transfer dm data from rs232 to plc then from plc i turn on...
7,834
azucop
A
Hello, someone have an example of an comunication between an Omron CJ2M CPU33 with FINS TCP to PC? Thanks for help
1,391
Hello people Has anyone managed to perform an arduino communication with an omron PLC through the FINS TCP/IP protocol? I already managed to do...
2,176
