Omron NJ101 PLC and Cmore EA7 HMI
jt66383
Apr 2020
Ontario
Has any one connected the Cmore panel to an Omron NJ PLC if so how?
I have been reading up on the FINS communication protocol, Seems a bit fuzzy.
Jeff
See Attached. File was too large.
Set is up under Memory Settings in Sysmac Studio.
You need to use the % character to prefix the CJ memory address.
I have used this function (%W11.00) when using an Omron NB HMI.
What I am wanting to do is set up the IP communication with an Automation Direct Cmore EA7-T7CL Hmi
So I don't have to mess with the FINS settings, Just configure and IP address int he HMI plug the EA9 into network switch and it will start to communicate?
I do see that my test address (%W11.00) the correct format.
Don't remember if there might be something else you need to do.
Customer was going to send me a document of what all he did, but never received the document.
I think this should work.
I'm new to the Omron world and struggling a bit with transferring data from one NJ controller to another. The first thing I want to do is a...
996
Hi, I want to control an AB Powerflex 525 drive over Ethernet/IP by using a Omron NJ101-9000. It seems that I would need an EDS file to...
1,450
I am just getting started with a Omron NJ and am trying to get a basic ladder to work. I am sure I am missing a step or something. When a input...
1,496
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
145
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
63
