Omron NJ101-1000 - First Program Problem
Timk5000
Aug 2015
Poplar Bluff MO
I am just getting started with a Omron NJ and am trying to get a basic ladder to work. I am sure I am missing a step or something.
When a input comes on it turns on an output.
I have setup 2 Global Variables - Sensor, BOOL and Valve, BOOL
I/O Map - NX-ID5442 - Input Bit 00,R,Bool, Variable=Sensor,Type=Global Variable
NX-OD4256 - Output Bit 00,W,BOOL Variable=Valve, Type = Global Variable
In Programs-Program0-Section0 I have 1 line
____[ Sensor ]____________(Valve)
When I run the program the Sysmac software shows the input coming on when its supposed to the light for input 00 on the plc comes on as it should.
The problem is that Sysmac software show the correct output coming on but the actual output on the PLC does not.
The PLC indicates that it is in RUN Mode. But I do not get any output.
Any Idea what I may be missing
I'm new to the Omron world and struggling a bit with transferring data from one NJ controller to another. The first thing I want to do is a...
998
Hi, I want to control an AB Powerflex 525 drive over Ethernet/IP by using a Omron NJ101-9000. It seems that I would need an EDS file to...
1,451
Has any one connected the Cmore panel to an Omron NJ PLC if so how? I have been reading up on the FINS communication protocol, Seems a bit fuzzy...
2,547
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
174
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
