Omron NS10 Screen Flash Card Problems
rory
Nov 2005
NELSON
29
I have two nearly identical machines running nearly identical programs. One works fine, the other not so good. They are data logging to the flash card in the screen. The problem is it is not always saving I have a check for this and it pings the SB47 save error flag and displays a pop up.
The odd thing is it won't save, you can try again and it won't save, but if you pop the card out then put it back in it will save again. Dosen't happen all the time just every now and again.
Tried differnt cards and have the same problem, the code that does the saving is identical, I have checked and checked checked for typo's. I'm starting to think the screen flashcard port might have a fault, seems unlikely though.
Maybe they were shaken while shipped.
Any words of Wisdom?
Are you using an Omron flash card? All cards are not equal and I have heard on people having problems with various flash cards before.
Crossed my mind, not using Omron, they only go to 128M using 512M this about my 7th machine saving to flash card, used the same brand card every time and tried other flash cards.
For cost vs hassel be worth a try.
Rory
If you format them in the memory card slot in a CJ1M or similar using CX you can use just about any brand.
Hi I am having trouble with t a NS10-TV00B-V2 touch screen (I think)Some buttons change colour but not all buttons seem to work, I have tried a...
3,125
Hi, Problem: Setting alarm relay. The screen has a nice alarm screen. I need to know whether un acknowledged alarms exist on the screen. I have...
4,931
Howdy, I’m working with an Omron CJ2M PLC and am hoping you can point me in the right direction… I’m trying to get the NS10 HMI/PT to talk to...
1,405
This HMI has been on my desk for only a week and has developed a stuck pixel which always shows blue. There doesn't appear to be any utility in...
2,146
I have exsisting system which we are upgrading the two HMI's from Omron NT's to new NS's. Thease will continue to comunicate via RS232 to the...
6,034
