Omron nt630-st141b-e
Mar 2009
Leeds
49
I've been asked by a Clent if it would be possible to change a logo on this particular HMI as they have bought some second hand equipment. They do not have the original project/HMI software or cable.
So my question is to any one with experience with this hmi is if I was able to get a copy of the programming software and cable. Would I be able to upload a copy of the installed software. Then be able to edit the text/logo and download it back to HMI. If so what cable and software would I require.
Are these HMI's similar to Siemens HMI's where this is only possible if the original programmer chose to download entire software and also enable the upload function.
you will need to Purchase CX-ONE Omron Programmimg software
the RS 232 coms cable wiring can be found in the documentation
Can I just comfirm before we buy any software that the following is definitely possible:
To upload the project out of the HMI in a form that will let you edit it and then download it back to the HMI.
I had never actually tried that procedure so I took a 5 year old NS-5 terminal that I have here and uploaded the program from it. CX-Designer requires you to save the file from the terminal then open it for editing, but it comes up as a complete copy of the program.
I have never used the NT-630 terminal, but it seems like it should work way as the same as the NS-5 does.
Sorry I actualy got the part number slightly wrong its a NT620C-ST141B-E
Anyway I found that OMRON have a vey good Technical Support Helpline here in the UK and they have told me what I want to do is possible and I can download the software for free once I've registered on their website.
www.myomron.com//downloads/4.Products/Software/NT/NTST/NTST-EV4.82.zip
I was also told that the RS232 cable used is not standard so I would need to look for the pinout to make one up.
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
174
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
110
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
259
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
144
