Omron NX1P
aandjsam
Sep 2016
lincolnshire
30
Hi all,
I've got an Omron NX1P2 PLC here that a customer has given me. The ethercat port is faulty. He's asked me to transfer the program onto another CPU, however I cannot access the program, as only the executable program has been downloaded to it.
Is there any way of transferring this from one PLC to another? either with SD card or similar? Not interested in modifying the code, as they're happy that it works OK. I simply want to transfer it onto a new PLC.
TIA
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
45
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
185
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
74
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
114
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
272
