I have only used AB so this is my first go with Omron. I need to change DM150 in a CQM1 CPU21 to another value.
I was able to get online with this unit and I was able to transfer the DM from the PLC and was able to view it on my laptop. To do the edit is it just the case of type in a new value and send the Selection to the PLC?
I wasn’t able to test this as they were shutting down so I will be back in the morning.
Also the current value is 98 Hex which is equal to 152 in decimal. The help files mention the Set Value [SV] is in .1 sec intervals so if this is the case then this timer is currently set for 15.2 seconds. I am correct or all wet?
